Shopping list for drum to disc conversion on 04 elantra
I'm looking for someone who has the parts list to do a complete rear drum to disc conversion on an 04 elantra. I've already converted the front over to Brembo cross-drilled OEM size rotors, 6-piston calipers, semi-metallic pads, etc. I'm trying to convert it over in the back to put the same setup on the back of the car. I was told by a friend with a Tibby that I could use the rear setup from his old car (sitting in the yard). That it would swap out pretty easily. Any information would be helpful!
While a GK Tib (2003-09) will work you will have 5-lug hub instead of a 4-lug like what is stock and on the front. You'll need to find an Elantra hatchback for 4-lug hubs and rear discs. Older RD Tibs (pre-2002) with 4-lugs won't work
