speedomitor ramges while driving steady
Old 10-31-2011 | 02:39 PM
david s's Avatar
Default speedomitor ramges while driving steady
Hey folks I have 2002 elantra while driving say on the highway the speedometer drops to zero and back sometimes stays there for a little while and comes back. Sometimes it just bounces around and settles back down to the speed you think you are going. Any ideas???
Old 11-13-2011 | 05:37 PM
Floridaelantrajoe's Avatar
Default Mine, too
My tachometer works fine. My speedometer is all over the place. Odometer only works when speedometer works. About 50% of time.
I have been told there is an input sensor, an output sensor, and MAYBE a VSS. Looking at autoparts.com, I see something different - a wiring harness for passenger-side and a wiring harness for driver side. Each is about $165.
So... What do I buy:
input sensor?
output sensor?
VSS?
Wiring harness for ____ side?
Thanks!
Old 11-14-2011 | 07:44 AM
No one has answers for me on my speedometer?
Old 11-15-2011 | 10:16 AM
Flyboy121785's Avatar
Most vehicles now adays have whats called an electronic speedo sensor. Basicaly what it does is clock the revolutions on a special rail that has magnets on it. Each time it passes it sends a signal and the pcm decodes it to figure out what speed the vehicle is going. The PCM then sends the information to the dash speedo. 2001-2002 Hyundai Elantra Speed Sensor - Auto 7 560-0019 - At Transmission
There is a link to one for sale from apwarehouse. The best thing to try first, however, is locating the sensor. I've never messed with these and don't have my manual with me. However if I remember correctly it is located on top of the transmission towards the fire wall. Check the cables and apply a cleaner to the plug to clean it. Next apply di-electric grease to the seal of the plug. Drive it and see what happens. After that it can be an issue such as a bad ground wire or possibly the sensor is on its way out. I hope this helps you and can solve the issue.
As I said I believe this is where it is at but as soon as I get access to my manual I will post here to let you know for sure.
Old 11-17-2011 | 09:33 PM
Veilside1's Avatar
it's the Vehicle Speed Sensor (VSS). Had same problem on an older honda i used to own
Old 11-18-2011 | 08:17 AM
Default elantra speedometer
Is VSS the same as input sensor and output sensor? I have ordered input sensor and output sensor from Fourgreen Auto Parts. Should arrive today. Do I need to order something else?
swetalgajjar
06-05-2023 06:40 AM
wtbbjb
01-25-2014 07:09 PM
02sonata
03-25-2010 03:13 AM
chrisnet
09-17-2008 01:15 PM
james1983
09-21-2006 12:27 PM
Quick Reply: speedomitor ramges while driving steady
