weight reduction
Old 05-09-2008 | 07:45 AM
elykatupac's Avatar
Default weight reduction
what can i do to my car to make it lighter? what engine/exterior parts can i change and where can i get them?
Old 10-23-2008 | 12:51 AM
AusDel's Avatar
Default RE: weight reduction
If yowould like to go all out and not care about the comfortsd e.g. aircon then a few minor suggestions are remove the aircon (10-15Kg) remove the radio and speakers (13kg) replace the wiring harness with teflon cable (30-45kg) take out the sound dampening off the floor and fire walls (Use dry Ice to do it is much easier this way anywhere from 20-40Kg)
Hope this helps
Old 10-27-2008 | 10:21 AM
Rdturbulence's Avatar
also you can get rid of your rear seats,replace the fronts with race seats, replacing the stock exhaust with a s.s. exhaust, manifold withaheader, replace the stock rims with lightwieght race rims. remember every little thing will eventurally add up. i've seen tiburons and elantras that claim a 2K lbs. dry weight. thats around a 600-700 weight reduction, they claim that for every 100lbs lost, a 10th of second is gained in the 1/4mile run, but also depends on the car, for a light wieght car like an elantra, it could be more. good luck
dmeza@gordonprill.com
04-27-2011 02:54 PM
poppyboo
03-12-2011 04:35 PM
ktp
09-11-2010 11:20 PM
Double J
03-30-2008 11:35 PM
ps0303
03-01-2007 12:02 PM
