DIY horn replacement for Touring?
Old 06-25-2009 | 08:16 AM
frodo19v's Avatar
Default DIY horn replacement for Touring?
I'd like to replace the existing horn with something a bit louder and more "fun" ... does anyone have suggestions/kits/links that a non-mechanic like me could use to replace the standard horn? Don't really want to add in a compressor, but will if absolutely necessary.
Does replacing the horn void any warranty?
Thanks!
Fred
Old 06-25-2009 | 09:47 AM
gunwaleman's Avatar
Yeah, the horn is a bit wimpy. So far, my only complaint. Where did they get that? Luckily I live out in the country, don't need to use it too often.
Old 06-25-2009 | 11:22 AM
Here's the horn you want:
Hella Horns
Loud As Can Be!
Tired of those wimpy, factory installed horns? You'll get some respect with these. I only honk my horn when it's absolutely necessary. For those times I do honk my horn, I want to be noticed. And just in case you haven't noticed, stereo systems are getting louder and interiors are getting quieter, which means you need to be heard! Plastic? No way! Durable, metal casing for years of survival. Easy installation. If you have horns presently, just swap the horns and use the existing wiring. If you want to add them to your present horns, a relay and directions are included. Loud as can be! 118 dB
http://www.griotsgarage.com/product/...rrivals&page=1
Old 06-28-2009 | 08:05 PM
miniceptor86's Avatar
Hi,
You can also use Fiamm's. Available at NAPA, Riderwearhouse, about $15.00 ea, get two, a hi and a low tone. You might need to use a relay due to the extra power they will draw over the stock unit.
Jim
Old 09-08-2009 | 05:42 AM
kman's Avatar
Nova, what if there is only one horn in the car? Can I wire the high and low note horns in Series or in Parallel?
Old 09-08-2009 | 10:31 AM
You should be able to do that.
Old 09-09-2009 | 12:44 AM
kman's Avatar
In parallel or in series?
Old 09-09-2009 | 08:24 AM
It shouldn't matter. Either would work. Personally, I'd do it in parallel.
Old 10-14-2009 | 03:09 PM
williama's Avatar
Hey...that's how my ET got it's name. Meep! Meep!
I didn't test out the horn until I got it home and could not stop laughing. Let us know how the replacement works out.
EricS
04-20-2014 01:58 PM
CamronTheGreat
05-07-2010 10:31 PM
WillPartHyundai
08-03-2009 03:36 PM
mikibark
08-14-2007 08:53 AM
jweidler
04-30-2007 02:51 AM
