Need info re wheels & tires
Does anyone know which 15" rims and winter tires will fit on my 2010 ET hatchback? I am very bad at this. Although I've spent hours on line, I can't figure it out. (I hope ET stands for Elantra Touring)
Tires come in a wide range of sizes (obviously) and you want to try to match the outside diameter of the tread as best you can. You already have 15" rims/tires on so you want to get as close to those measurements as you can. Traditionally they are listed as treadwidth/ratio/rim-size, so you want a 195/65/15. This means the tread is 195mm wide, the side wall height ratio is 65%, and the rim size is 15 inches. Deviate too much from these numbers and your handling and speedometer accuracy will suffer.
There are 3 important numbers with rims. Lug pattern, offset (how far they stick out), and center bore (hole in the middle of the rims). Stock is 5x114.3mm (or 5x4.5") lug pattern, 45mm-55mm offset, and a 67.1mm center bore.
I have been looking for gently used winter tires and rims for my 2010 ET as-well and allowing a range from 185 to 195 for a 65/15, or a 195 to 215 for a 60/15. These ranges will allow for a maximum of 2mph error at 80mph. Hope this helps!
Johnzz1420
07-15-2012 05:21 PM
Wisconsin-Autocrosser
11-18-2010 10:51 PM
