radio removal
radio removal
Hi have just got i30 want to install a parrot bluetooth but there is part on top of the dash which i am not sure how to remove think it called crash pad it looks like it is just pushed in. any ideas how to remove. Thanks
From http://www.hmaservice.com/ for a 2010 Elantra Touring, US version of the i30.
ELANTRA TOURING(FD) >2010 > G 2.0 DOHC > Body (Interior and Exterior) > Interior > Crash Pad > Repair procedures
Replacement>Cluster Facia Replacement
NOTE
• When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
• Put on gloves to protect your hands.
1.Tilt the steering column down.
2.Separate the cluster facia panel (B) from the crash pad pulling the SST (A) (09840-1E100).
3.After loosening the mounting screws, then remove the cluster fascia (A).
4.Disconnect the connector (A).
5.Installation is the reverse the removal.
NOTE
• Make sure the connector is plugged in properly.
Center Facia Panel Replacement
NOTE
1.Remove the nat (A).
2.Remove the upper tray (A).
3.Put the SST (09840-1E100) (A) into the space between the center fascia and crash pad.
NOTE
• Be care not to damage the center facia and crash pad.
4.Separate the center facia panel (B) from the crash pad pulling the SST (09840-1E100) (A) as shown on the photo.
CAUTION
• Pull the SST (09840-1E100) (A) slowly not to damage the center fascia panel.
5.Pull the other side of center facia panel with the SST (09840-1E100) in the way of "step 2)".
Center Facia Lower Tray Replacement
1.After loosening the mounting clips, then remove the center facia lower tray (A).
2.Installation is the reverse of removal.
Lower Panel Replacement
1.Remove the crash pad side cover.
2.Disconnecting the connector (B).
3.After loosening the crash pad lower panel mounting screws, then remove the lower panel (A).
4.After loosening the mounting bolts, then remove the reinforcing panel (A).
5.Installation is the reverse of removal.
Audio Assembly Replacement
1.Remove the center facia panel .
2.Loosen the audio (A) mounting screws.
3.Disconnect the connector (A).
4.Installation is the reverse of removal.
NOTE
Glove Box Replacement
1.Disconnect the damper (B) from the glove box (A).
2.Remove the glove box (A) from the lift (B).
3.Disconnect the pine (A), then remove the glove box (B).
4.After loosening the mounting screws, then remove the glove box housing (A).
5.Disconnect teh connector (B).
6.Installation is the reverse of removal.
Shroud Replacement
1.Loosen the screws.
2.Remove the shroud assembly (A).
3.Installation is the reverse of removal.
Crash Pad Side Cover Replacement
NOTE
1.Remove the crash pad side cover (A).
Driver's
Passenger's
Crash Pad Replacement
Note:
1.Remove the following items.
A.Front seat.
B.Cluster fascia panel, cluster.
C.Audio assembly.
D.Glove box.
E.Crash pad side cover.
F.Front pillar trim.
G.Lower panel (L/H)
2.Remove the photo sensor.
3.Disconnect the passenger`s air bag connector.
Loosen the bolts and nuts, then remove the crash pad (B).
NOTE
• Make sure the crash pad fits onto the guide pins correctly.
• Before tightening the bolts, make sure the crash pad wire harnesses are not pinched.
• Make sure the connectors are plugged in properly, and the antenna lead is connected properly.
• Enter the anti- theft code for the radio, then enter the customer`s radio station presets.
NOTE
NOTE
NOTE
NOTE
CAUTION
NOTE
Shroud Replacement
NOTE
Driver's
Passenger's
Note:
A.Front seat.
C.Audio assembly.
D.Glove box.
G.Lower panel (L/H)
NOTE
zainecurtis
04-05-2013 02:34 AM
