Touring recall for noisy front end
front strut noise
Will the key factors are I think are Claim type CPN, Cause:CPN 00C53a1 Fd Front Strut Noise (10-01-030), 6941 WHY. I think thats the major points. I was told about this at the dealer when I was having another matter fixed. Hope this helps I would try calling service department first. There was N/C (sealed front strut boots)
I have been having noise come from the front end of my new ET. The noise is intermittent. It usually develops after driving on a winding road and then the front end makes groaning noises for the rest of the day. I do not drive aggressively, but several roads I frequent here in the mountains are steep with alternating switchbacks that I take about 35 mph. The noise is comparable to the groaning noises my 2001 Ford Focus Wagon made after 100,000 miles. I was told the Focus needed new struts.
I dropped off my Elantra Touring for its first oil change today and talked to the service manager about the problem, but told him that the car was "quiet" at the time. We made an appointment for next week to look into the front end issue, but I went ahead with the oil change. When I got in the car after the oil change, the noise was immediately evident (caused perhaps by a couple trips up and down the lift with the suspension hanging free), so I went back and the service manage had one of the techs go for a ride with me.
Per my tech, there is NOT a recall in place for the Elantra Touring, but there is one for the four-door Elantra. The front ends on the ET and 4-door are identical, so he made the recall repair as called for on the 4-door. Per the tech, this involves gluing the upper strut boot to the metal plate that the strut attaches.
So far today, the car has been quiet, but the dealer is holding my appointment for next week if the sounds return.
Look for an update next week.
I took my car in for a squeaking front end. They changed the bushings around the struts. Didn't do a single thing to help.
Drove a few weeks and a notice a clanking noise and I heard something fall from the bottom of my car. I stopped found a 4.5" bolt in the road.
I took it in with my next appt. It belonged to my transmission. They reinstalled the bolt, tightened other bolts and it has been silent since.
I had a noise which could only be described as a wooden ship groaning on the water. I was able to recreate the noise by either pushing down on the top of the drivers side fender near the windshield or by going over a small bump in the road 1 wheel at a time.
The dealer kept my car for 4 days. They lubed the front end, changed the strut, changed the sway bar bushings but the only thing that seemed to work was they changed the spring and so far the noise is gone.
