Cleaning the throttle plate
I知 a new Hyundai Tucson owner 2016 with a non turbo 4 banger. I知 want to clean the throttle body/plate because it looks like a smothered freshly painted mess. My big question is do you need a high end scanner to reset the computer or plate to get it to run right? Other then the throttle body this is a great running vehicle.
Thank you you for all of your help.
I would not move the throttle plate manually
Use the accelerator pedal.
Find a piece of wood or pipe and use it to depress the gas pedal
This should open the plate or position the plate to where you want it
That way its setting doesn't get messed up
I could be wrong??
I could be wrong??
tmtauto
12-07-2012 07:21 AM
Jamnaccent02
11
11-22-2007 04:05 PM
