Hyundai Getz Offering a sportier look than the Atos, the Getz preserves the economy of the sub compact market in both the 2 and 4 door models.
2004 Getz warning sound
Old 08-30-2010 | 11:28 AM
David54's Avatar
Default 2004 Getz warning sound
When the car is stopped and ignition turned off and drivers door is opened there is a warning alarm. Any idea what this may be? Al other doors and boot are closed and lights are off.
Thanks for ny ideas
Old 08-30-2010 | 12:40 PM
Is the key in the ignition?
Old 08-30-2010 | 12:43 PM
David54's Avatar
Default getz warning sound
no. the key is out. when i shut drivers door it stops
Old 08-30-2010 | 01:53 PM
Does the sound change at all when the key is put in the ignition? And does the sound happen when the engine is running and the drivers door is opened? Did this just start happening? My only guess is there is a fault with the ignition that thinks the key has not been removed.
Either that or some other sensor that North American cars don't have. Maybe it's warning that the parking brake is not applied or the shifter is not in gear. Is it a manual or automatic?
Old 08-30-2010 | 02:11 PM
David54's Avatar
Will check that. Many thanks for your help.
Enjoy your day
David
Old 08-30-2010 | 02:22 PM
David54's Avatar
Hand brake is ok and still sounds with key in ignition and engine turned off as soon as drivers door is opened. Taking key out does not stop beeping.
Old 10-20-2010 | 08:34 AM
petsnpotions's Avatar
Hi there!
I am a newbie, but I think I may have the answer you are looking for! I had the same problem with my Getz. The alarm is your stereo telling you to remove it, if it's the same as mine it should be a Sony face off? If so, remove it. The alarm only sounds for a bit then goes off, it's just reminding you to remove it, it's a security measure!
Have you ever had any problems with a squealing fan belt? Whenever it gets cold or damp when I start my car the belt briefly squeals, then it's fine. In the summer or when it's hot it's fine, only happens when it's cold. 60 seconds after the car has been running it's fine. I've had a new fan, power steering belt and a new battery, but it still does it when it's cold. Have you had this happen?
churnedprism
04-22-2011 08:58 AM
NNH
08-24-2010 02:03 PM
EgelRattes
02-10-2010 05:58 PM
Sauerzbr
01-02-2007 10:37 AM
00sonataGLS
05-19-2006 09:44 PM
