02,2.4 quit on freeway
Old 08-26-2007 | 07:42 PM
tobo57's Avatar
Default 02,2.4 quit on freeway
My daughters 02,santa fe2.4 just stoped running on the freeway.The wrecker guy replaced the cam sensor and still will not run,said it may be crank sensor.Fuel ok,no spark.Belt replaced at 60,000 and now has 105.
whatsup and where do I go from here,thanks tobo57
Old 08-27-2007 | 09:20 AM
Doohickie's Avatar
Default RE: 02,2.4 quit on freeway
Crankshaft position sensor is a common one that will go out and make the engine not run; they should be able to check it before replacing it though.
Old 09-06-2007 | 09:43 PM
tobo57's Avatar
I found the problem.The counter balence belt broke and tore up sensor.Timing belt replaced at 60,000,I'm thinking the small belt should have been replaced at that time by dealer and lasted till the 120,000 mile service.So at 105,000 I had both belts and water pump and crank sensor replaced.
brood86
08-03-2024 08:12 PM
lenny
08-30-2014 12:12 AM
joe327
03-03-2014 04:56 PM
blumonster
09-06-2011 08:57 PM
SmallTown
07-05-2006 03:52 AM
