'05 Santa Fe Oil Type
Old 05-25-2009 | 06:27 PM
kerryman71's Avatar
Default '05 Santa Fe Oil Type
Hello,
I am due to change the oil in my wife's 2005 Santa Fe V6 2.7L AWD. It has a little over 61,000 miles on it and I've always used 5W30 and original Hyundai oil filters. I was reading in the owner's manual today that you could use 5W20 oil as well.
I was just wondering if anyone here uses it and what they think about it protection and performance wise. Experiences good and bad are wanted. Thanks.
John
Old 05-26-2009 | 08:19 AM
jsinton's Avatar
Banned
It depends on where you live, and what kind of driving you do. If you drive really hard in hot climates, or in a lot of city traffic, then I wouldn't do it. If you take it easy, and don't drive to fast with lots of highways in a not too hot climate, then it's ok.
Old 05-26-2009 | 11:15 AM
kerryman71's Avatar
Thanks for the reply. It's a mix of city driving and highway. I live in Massachusetts. I talked with the service manager at the local Hyundai dealer and he suggested sticking with the 5W30. I change my own oil religiously and the car runs beautifully with just under 62,000 miles on it. I guess if it ain't broke don't fix it comes into play here. I'm just looking for the maximum life out of the engine, which I'm sure I'll get if I just keep doing what I'm doing. Thanks again.
John
Old 05-26-2009 | 11:53 PM
ken99's Avatar
With computer controlled milling technology, the tolerances on new engine built in the past 8 to 10 are much closer than before, permitting the use of thinner viscosity oils for lubrication. Thinners oils also usually translate into better mileage, so auto makers have moved towards 5w-20 as the standard weight oil for new cars. You Santa Fe was likely sold new with 5w-20 in the crankcase. I agree with the others, stick with the 5W-30. If you ever end up towing a small trailer or get stuck in stop & go traffic, the heavier viscosity will provide an extra measure of protection.
Old 06-07-2009 | 10:22 PM
anonymouse's Avatar
Put Mobil 1 or similar synthetic in and do not look back. Makes a huge difference to how smooth mine runs.
kerryman71
05-18-2009 03:18 PM
c7scayman
02-24-2009 08:27 AM
chaos133
05-28-2008 08:46 AM
HalfAF
09-21-2007 09:15 PM
ps0303
03-01-2007 12:02 PM
