2004 Santa Fe 3.5 Won;t hold Idle
Old 02-08-2010 | 12:36 AM
v1vrfly's Avatar
Default 2004 Santa Fe 3.5 Won;t hold Idle
Hi,
Need some input on a recent problem that popped up.
After about 2 hours driving on the freeway to home this evening, I stopped the car at a traffic light and the card died. I tried to re-start but wouldn't start, hold idle.
So, I started it again, this time with a bit of throttle and it started, but wouldn't hold idle without some throttle applied.
Anyone with experience on this, guess?
Thanks
Old 02-09-2010 | 09:37 PM
drivinfaster's Avatar
will it run at wide open throttle?? if so, then mash on the gas up to rev limiter (or even more if you wish, i won't tell...). you may have dislodged a piece of carbon into the egr system from the long cruise. this sort of thing can happen from time to time. i suggest a top engine cleaning, or some sort of fuel injection service (no, not the stp mechanic in a can pour it in the gastank and everything will be fine stuff). i suggest a 'motor-vac' by snap on. there are several service centers that use these, or the b&g units, either one will give you a far better service than the bottles of mystery oil on the shelves in the stores.
if it doesn't run at wide open throttle, then you may have other issues, but i think it will be carbon. you chould also have the throttle plate cleaned as well.
hope this helps.
df
Jacob1980
07-09-2015 11:51 PM
sipos
02-01-2011 08:45 AM
Hatdrawn
04-27-2010 09:49 PM
cjorden
11-19-2008 03:19 PM
nhman
03-26-2008 04:55 PM
