2005 Santa Fe
Old 02-13-2010 | 10:09 AM
pocahontas1960's Avatar
Default 2005 Santa Fe
My ABS,TCS and brake lights come on at about 65 miles and he all the time and only go off when engine is shut off. I had new brakes put on and nothing change, what can be the problem?
Old 02-13-2010 | 10:12 AM
Does your cruise control work?
There is a recall for the brake light switch on the brake pedal. It controls not just the brake lights but the TCS, ABS and cruise control. Take it to a dealer for a free replacement. Tell them you are bringing it in for the brake light switch recall.
Old 02-13-2010 | 10:14 AM
Old 02-14-2010 | 06:01 PM
yes my cruise works but it has shut off in the past for no reason. Thank you so much. I looked for any recalls but didnt see this one.
Old 03-06-2010 | 09:33 PM
Wrong application !!
Campaign 092 does not apply to 2005 model or 2006 (SM) , 2007 (CM) is applicable.
I would be more concerned with a loose/cracked tone ring at the front axles.... scan for codes first. and not at Auto Zone, need HI-SCAN or GDS to access them module for code(s) -- dealership --
madmongodog
05-25-2010 07:59 PM
joybaba
04-06-2009 06:37 AM
Dalem
09-11-2008 11:11 PM
DeNobregaInteriors
03-15-2008 12:08 AM
75kaine
11-08-2006 09:17 PM
