2007 2.7 gls engine problems
Old 02-01-2012 | 06:22 PM
CTMS2007's Avatar
Default 2007 2.7 gls engine problems
I have a 2007 gls with a 2.7. I am trying to find an engine diagram for it. It is showing a 131, 137, 300, and 301 engine code. I have pretty well figured that the o2 sensors are shot, but I still wanted to go through the motions and rule out anything else first. I have been trying to look online and find out where the number one cylinder is. I am guessing that it is in the front on the far left, but I am not certain of that or the firing order. Also, if I am not mistaken, that would mean that bank one sensor one and sensor two should be between the radiator and motor, and also after the cat on that same pipe. Is this correct, or am I way off base?????? Thank you in advance for any help that you might offer.
Old 02-01-2012 | 09:57 PM
This pic should help:
Bank 1 is the bank of cylinders on the firewall side
Bank 2 is the bank of cylinders
on the radiator side
Sensor 1 is the O2 sensor before the cat
Sensor 2 is the O2 sensor after the cat
georgejw22
09-02-2021 04:16 PM
cpl.mooney
03-26-2012 02:18 PM
linda01
12-26-2011 09:17 AM
jasonlyy
03-04-2008 02:01 PM
pcpat
02-07-2008 03:52 AM
