2007 Santa Fe Headlight
Old 12-13-2017 | 11:29 AM
JohnCV's Avatar
Default 2007 Santa Fe Headlight
Can someone please verify how the front headlights of a 2007 Santa Fe "should" operate? Specifically, there is an inner and outer bulb in each headlight assembly. The outer bulb is always on when the head lights are on. It's a low beam bulb. While, the inner bulb is only on when the high beams are on. Is the inner bulb only for high beam or should it also operate as a low beam?
Thanks much
Old 12-13-2017 | 03:50 PM
avisitor's Avatar
One low beam and one high beam on each side
Old 12-14-2017 | 07:06 PM
hyundresc's Avatar
This is a good discussion on the subject. May help
Hyundai Santa Fe Headlights Problems
Old 12-14-2017 | 07:38 PM
Thanks much
Operates correctly. Low bean should go off when high beams go on.
Old 12-15-2017 | 09:50 AM
JohnCV's Avatar
Thanks for confirming the correct low beam/high beam bulb operation.
Driving at night with just the low beams is not effective. The low beam bulbs are on, but the illumination on the road does not seem to be enough. I spent some time adjusting the headlight angles and noticed a slight improvment. Further, the clear plastic of the headlight assembly is not in bad shape.
Any ideas?
jk1nole
03-23-2015 06:13 AM
Michael Andrew Sievers
02-14-2012 04:41 PM
murkstreaks
12-08-2011 08:51 AM
ceniel
01-23-2009 10:00 AM
ski.scott
05-17-2007 12:41 AM
Quick Reply: 2007 Santa Fe Headlight
