2008 Sante Fe Resonance Rattle
Old 07-21-2009 | 11:16 PM
Omegahawk's Avatar
Default 2008 Sante Fe Resonance Rattle
My 2008 Sante Fe has only one irritating problem. At around 1950 rpm I get what sounds like a right rear exhaust system heat shield vibrating. In gear or out, hot or cold, as the tach passes just below 2000 rpm it can be heard and then with more or less rpm it's gone. Trying to hold a steady ~1950 rpm to find this noise is no easy trick . Any ideas?
Thanks
Old 07-22-2009 | 05:05 AM
cbezanson's Avatar
I was hearing something rattling when I would go over bumps back there and it turned out to be the license plate frame. I tucked some foam underneath it. I haven't had any sounds like yours, though.
Old 07-23-2009 | 12:52 PM
cdoo's Avatar
Default Cvvt?
I have a Nissan with a similar issue, there is a vibration at a specific point in the rpm range. The only thing it has in common with my santa fe is the CVVT/continously variable valve timing.
My opinion on my Nissan is that it is at a point where the valves and engine speed are at just the point of inefficiency and the engine vibration is greater. In your case, since engines and exhaust are all connected, there may be a point in your exhaust that reacts more to that vibrational frequency.
Gordy Klug
12-26-2023 06:14 AM
btd35
07-13-2013 04:41 PM
liberty_azera
04-28-2012 06:39 PM
sante fe 08
02-02-2012 12:43 PM
VTMinee
01-19-2011 09:28 PM
Quick Reply: 2008 Sante Fe Resonance Rattle
