ABS and TCS light
Old 06-12-2011 | 09:51 PM
Yes, they are steel and no, the can't be welded back together. The crack isn't the problem, it's the wider spacing the crack makes between the ridges.
  #12
Old 06-13-2011 | 08:23 AM
kerryman71's Avatar
Originally Posted by old4x4
What's the ring made of? I'm thinking if they're steel, they can be touched with a mig welder to fix the crack instead of going thru the expense of replacement. Just a thought.
The clearance between the ring and the speed sensor is pretty small so you'd probably end up with a bigger problem.
The ring itself only costs about $23, so if you can fix it yourself the cost is minimal. Even to have it fixed by a mechanic shouldn't cost that much.
John
  #13
Old 09-29-2011 | 05:04 PM
her69jb's Avatar
thanks guys...it was a tone wheel broken......on the passenger side....thanks very much for your help.......you are soooooo goood.....the problem is gone......finally..
  #14
Old 07-15-2018 | 12:54 AM
David D'Ambra's Avatar
Default Tone wheel
how much did the mechanic charge so I have an idea when I go. I’m have the same problem !
  #15
Old 07-15-2018 | 03:09 PM
We find it somewhat difficult to offer an estimate because the times are a few years different and rates and locations differ also. You could probably obtain a few estimates and make your decision from there.
Szabolcs Gyöngyössy
11-20-2019 04:56 AM
FabricGATOR
11-22-2016 02:41 PM
bradenhbu
11-08-2016 07:10 PM
RJOttman
08-12-2011 11:57 AM
Ladydi
08-06-2010 10:28 PM
