Check Engine - 2187/2189
Old 04-09-2013 | 12:25 PM
TonyB's Avatar
Default Check Engine - 2187/2189
I have a 2009 Santa Fe with 63K miles on it and yesterday at lunch the check engine light came on - it had been fine on my morning commute a few hours earlier.
I got the diagnostic codes - 2187 and 2189 - System too lean at idle bank 1 and bank 2.
The vehicle seems fine - running smoothly, no detectable loss of acceleration or performance. I'm hoping it may be an O2 sensor which could be a reason for these codes.
I called the dealer about it - I was just there for my 60K service. They told me if I wanted to bring it in it would be $95 do do the diagnositic - hook up the computer and get the codes. I told him I had the codes, but he insisted it would be $95.
I feel like I'm being scammed, but if there is an issue I obviously want to fix it and not just ignore it. I thought the folks here might have some advice on how to proceed - thoughts?
Old 04-10-2013 | 08:02 AM
A lean condition in both banks usually means a leak in the intake. Check the tube after the MAF and before the throttle body. Also look for intake manifold leaks and vacuum leaks (like a stuck open PCV).
Other problems could be a weak fuel pump (low fuel pressure) or a clogged fuel injector(s).
You SF should still be covered under the warranty of you are the original owner.
Old 05-11-2013 | 02:02 PM
TonyB's Avatar
Default MAP Sensor
I was finally able to bring the Santa Fe in for service and the issue has been diagnosed as a bad MAP sensor. I was told that said MAP sensor is only under warranty until 60K - I'm at 64K now but this probably happened at or very near the 60K mark (I've been waiting for an appointment at the dealer that works for me). About $250 to fix.
Seems to me that a sensor should have more than a 60K warranty. When I had a Subaru Outback the speedometer/odometer stopped working and Subaru tried to tell me that it wasn't under warranty, but we all know your speedometer/odometer is really NEVER supposed to break so they agreed to fix it gratis.
Anyway, I was advised to call Hyundai customer care and see what they would do for me - anyone ever having any luck getting Hyundai to pick up the tab on a sensor replacement like this?
Old 07-01-2013 | 09:57 AM
billkost55's Avatar
did you clean the MAP sensor ? i also changed the big clamp there and she runs a lot better. gotta run it for a few cycles then recheck the codes. Any progress on your end ?
sonata 2002 gls
05-03-2012 03:42 AM
outandabout
03-22-2006 07:31 PM
Lydia1
11-01-2005 10:45 PM
vlachan
09-24-2005 10:55 PM
tomholl
07-28-2005 01:53 AM
