Clinking noise when going into reverse or drive
Just wanted all to know that there is a tech bulletin out for a clinking noise when going from park to drive or into reverse...I experienced this, and mine was the 1st one the dealer did....Doesn't take alot of time, and they did a great job........I'm just wondering, after awhile, the plastic or nylon bushings they use will obviously wear out, and then this will probably get into an expense since they have to pull the axles to fix it.
