Clueless! Transmission won't engage!
Old 12-08-2011 | 09:28 PM
valentip83's Avatar
Exclamation Clueless! Transmission won't engage!
2001 santa fe 4wd 2.7L
Driving fine, out of no where lost momentum, engine was going but the wheels got no power. Now in D, R, 1, 2 all act like its in Neutral.
Pick up codes P0755 P0760 P0765 - Solenoids open/short or malfunction
Tried the following:
  • -Tranny fluid looks/smells fine
  • -Checked for opens/shorts at the solenoids, at all harnesses in between, found no abnormalities resistance readings in spec = 3.2ohms each
  • -Checked A/T control relay - works fine
  • -Checked ATM fuse - works fine
  • -Checked vehicle speed sensor, tested according to service manual only pulsed twice so replaced it with a new one, didnt solve the problem
The only thing I haven't tested in the TCM and torque converter
No clue what to do..
Has this happened to anyone else ? Any help is better than none
Thanks
Old 12-10-2011 | 11:38 AM
kerryman71's Avatar
The only problem I ever had was when my wife was driving the vehicle she said it would get up to only about 30 MPH and then the RPM's would go through the roof. I checked it out and after taking the engine cover off found that some squirrels had eaten some of the harness. Had it repaired and it was back to normal. Good luck. Hope it's something as simple as that.
John
jbuchyns
08-19-2010 10:22 PM
PCBFL
04-30-2010 08:36 PM
rgeldr
03-17-2010 09:44 PM
PanDeCoco
01-01-2009 12:41 AM
sunnydee
04-13-2007 03:19 AM
