dash warning lights
Old 02-25-2014 | 07:24 PM
daniel2229's Avatar
Default dash warning lights
Had to take in my 2007 Santa Fe to the shop tonight. Yesterday when I started the Santa Fe, the ESC and the ABS lights came on. The all wheel chassis light started flashing. I took out the ESC fuses, a 40 and a 10 amp from under the hood, and they were fine. Restarted, still have lights. On the way home from work, the Check Engine light came on.
This morning we had a bit of snow, so I checked the ABS, and they worked. Oddly enough the cruise control did not work. I wonder if they are somehow tied to the ESC?
Should find out what the problem is by tomorrow. Will update this post.
Daniel
Old 02-26-2014 | 10:37 AM
Old 02-27-2014 | 09:01 PM
daniel2229's Avatar
Right on both counts. I pick it up tomorrow after they change the oil. $300.
Thanks,
Daniel
Old 03-04-2014 | 02:49 PM
Ronster's Avatar
Daniel
You were lucky.... $300... Our 2010 Santy showed the same problems.
But we only had the speed sensor replaced at a WOPPING $437.00 !!!!
Warranty is over due to mileage. Time to think of taking it to somewhere
other than the dealers. Not too happy. No oil change !
Old 03-08-2014 | 08:16 PM
daniel2229's Avatar
The brake switch had a short and the speed sensors needed to be replaced. Had oil changed and tires rotated for $345.
Fortunately, I have a dealership that has never disappointed me or tried to take advantage, and let me tell you there have been dealerships in the past that have, and I never returned.
Daniel
psychodoodbrij92
03-28-2019 12:54 PM
ronnieoverholser
05-12-2013 09:57 PM
DOH
01-20-2009 08:47 PM
Sardot
10-25-2008 08:35 PM
Stujak
04-07-2008 07:58 AM
