Factory rims for 2006 question?
i jus bought a 06 sante fe that came with 20" rims. I would like to buy a set of factory wheels and tires and was wondering what years will fit? will tucson wheels fit as well?
thanks
thanks
A wide variety of wheels will fit. The 2006 Santa Fe has 16x6.5" wheels with a 5-114.3 bolt pattern. So just about any wheels that that bolt pattern will fit. That includes Tucson wheels as well as Veracruz wheels, 2007-up Santa Fe wheels, 2006-up Sonata wheels, Azera wheels, even 2004-up Tiburon wheels.
What size wheels do you want to run? I've replaced the factory 16" wheels on my Tucson with 18" wheels from a Veracruz. I now use the factory 16" Tucson wheels for winter tires.
i was sort of wondering if say , the wheels of a 2002 sante fe would fit a 2006 ect.
from what you mentioned - it looks like the sante fe , tucson and vera cruz all use and have used the same bolt pattern since day one.... is this correct ?
Yes and yes. 2002 Sante Fe wheels will fit. And all Santa Fe, Veracruz and Tucson wheels will fit. However, not all Hyundai wheels fit. Some cars like the Elantra and Accent have a 4-100mm, 4-114.3 or 5-100mm bolt pattern. Just be sure to get wheels with a 5-114.3mm bolt pattern.
This is the 2005-06 Sante Fe 16" wheel:
Here are some other options:
2001-2004 Santa Fe 16" wheel:
2007-up Santa Fe 16" wheel:
2007-up Santa Fe 18" wheel:
2005 Tucson 16" wheel:
2006-up Tucson 16" wheels:
2006-up Azera 16" wheel:
2006-up Azera 17" wheel:
2006-up Sonata 16" wheel:
2006-up Sonata 17" wheel:
2007-up Tiburon 16" wheel:
2003-06 Tiburon 17" wheel:
2007-up Tiburon 17" wheel:
2007-up Veracruz 16" wheel:
2007-up Veracruz 18" wheel (what I have on my Tucson):
Here's a pic of my 2006 Tucson with the 18" Veracruz wheels:
tosun
06-13-2006 02:33 PM
