Front Brake Rotor Replacement
Old 03-31-2010 | 07:46 PM
kennyjohn's Avatar
Default Front Brake Rotor Replacement
How do you remove the brake rotor? I removed the 2 phillips screws,but no luck. Is this rotor attached to the hub,or just rusted on/
Any help
Thanks
Old 03-31-2010 | 07:52 PM
Rust is wonderfull... crack them with hammer to get them off.
Old 03-31-2010 | 09:36 PM
They are rusted on. Here's a simple solution that works for most cars:
http://www.youtube.com/watch?v=mtsTJCRljAs
Old 04-06-2010 | 07:03 PM
kennyjohn's Avatar
Thanks ALL
The rotors were just rusted on,hit with a hammer a few times and off they went.
Thanks Again
Old 04-02-2011 | 03:20 PM
FlameOut's Avatar
I know this is an older thread, but does anyone have any other suggestions? I'm trying to remove the front rotors from my 04 (which has 03 rotors) and I've even resorted to using an 8 lb sledge with no luck at all. Why is nothing on this car ever simple like it should be?
Old 04-02-2011 | 10:07 PM
Old 04-03-2011 | 05:52 PM
kerryman71's Avatar
Try spraying some PB Blaster so that it will get in behind the disc and let it sit for a while. Try what is shown in the youtube video. If that doesn't work resort back to the hammer.
My friend's Highlander was like that. There were spots on the disc where you could thread bolts to break the connection but instead it actually tore the metal apart, that's how badly they were rusted on. After letting them all sit for a half hour I was able to get them off using the hammer again. Good luck.
John
word2yamutha
09-03-2015 12:17 AM
golfer2b
11-07-2014 06:11 PM
akkernight
07-25-2010 07:13 PM
Stryker
05-12-2010 12:17 PM
jmihal
06-28-2008 10:11 AM
