front console
Floor Console Replacement
- When prying with a flat-tipped screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damaged.
- Put on gloves to protect your hands.
2. Remove the consol under cover(A).
3. Disconnect the connector.
4. After loosening the console mounting screw, remove the floor console side cover (A).
5. Remove the armrest lower met (A).
6. Remove the stroage box console cover (A).
7. Disconnect the connectors(A).
8. After loosening the console mounting bolts and screws remove the floor console assembly (A).
9. Installation is the reverse of removal.
Armrest Replacement
1. Remove the console assembly.
2. After remove the rear console cover (A).
3. Disconnect the connector (A).
4. After loosening the armrest mounting nuts, remove the armrest (A).
5. Installation is the reverse of removal.
LadyCoops
12-27-2008 10:13 AM
