Frustrated.. Santa Fe 2.7 Won't Start- What else Can I try?
Anyone had similar issue? I have a 2004 Santa Fe 2.7, 2wd. Vehicle sat for several months. Required a jump to start then drove about 50 miles, turned off and wouldn't restart. (dash lights only). Charged battery overnight and vehicle started fine for the next couple of days. Now will not start with jump either. Engine not cranking at all dash lights etc. only, . Replaced battery, the alternator checked out fine. Replaced neutral safety switch. Have tried to start in neutral, reverse, etc. no go. vehicle starts up only when manually jump the starter. Replaced ignition switch also. Also, wondering why it would jump start with cables before and then suddenly will not. Any wisdom appreciated. Thank You
Solid CLICK when key turned to "START " position ?
Was the alternator tested while it was running, or engine off ?
Why ? You stated car cranked previously, you likely spent $$ to compund your problems/add kink to diagnosis
Ok, we allow engine crank to fire in "N"
reverse,
Not allowed to start in gear, we don't allow that, unless somebody manually by-pass safety parts
Then you need to diagnose that circuit
Replacing ignition coil next.
Why, ignition coil not make the engine crank
reverse,
Use a voltmeter that displays voltage numbers, test light is not valid testing tool.
There was no click at all. Dash lights
Tested on the car at Auto Zone (after we could still jump start it). Removed later when no longer would start with a jump or new battery, took to Auto Zone and they said it was Good
It only cranked when it started with a jump when we first got it. We had to tow it home because it would not start with a jump and there was no crank or click at all. Now has new battery. It has power going to the starter but none going to the solenoid, did use a test light...
(there is no crank in any gear)
reverse,
Thank you, can you explain the proper procedure to go about this?
Replaced the ignition switch, Very Sorry. Not the coil
Thank you for taking your time to reply, pretty puzzled right now.
reverse,
