H4-60NH bulb, GE NightHawk Platinum
Old 12-31-2010 | 11:40 AM
cmobile's Avatar
Default H4-60NH bulb, GE NightHawk Platinum
I have an 03 Hyundai Santa Fe and want to run GE nighthawk Platinum bulbs. I found a set on Amazon but they are a H4-60N/BP1 Motorcycle light.
http://tinyurl.com/2ayueca
I think H4 is essentially the same as a 9003 other than perhaps filament placement, the socket is the same.
Is there a difference in motorcycle vs automotive bulbs. It doesn't specify the wattage, but I assume 51W is the max (DOT legally) for auto. Is it the same for motorcycles?
Don't necessarily need GE nighthawk platinums but sylvania silverstar's burn out to quickly, ~1 year. So I was looking for an alternative light output with more longevity.
Thanks
Chris
Old 12-31-2010 | 01:05 PM
H4 is just a bulb designation (H4 for European and 9003 for USA). Used in motorcycle lamp and HELLA lamps I been using on my Toyota, and many other vehicles..
I pitched the 60/55 in the bike and car in favor of the 100/90 or 100/80 depending on availability.
Osram, Phillips, Hella all good bulbs to use. My current set is OSRAM 100-80, exploded 1 a while back due to water in lamp housing.. so I gots a 60/55 on 1 side right now.. The high watt bulbs seem to last a pretty good long time for me, other than explode 1 due to water in lamp.
Old 12-31-2010 | 11:11 PM
cmobile's Avatar
Thanks for the
neuroticsonata
04-13-2013 11:28 AM
Rick44087
11-29-2009 04:37 PM
nashjared1
10-10-2007 05:12 PM
bigepley30
07-25-2007 11:17 PM
Jen
09-15-2006 04:48 PM
