headlights on 2004 sante fe gls
Old 10-01-2010 | 12:43 PM
irishlass3's Avatar
Default headlights on 2004 sante fe gls
How do I remove lens to clean inside headlights? Afraid if I push or pull to much I will break plastic holding lens in
Old 10-01-2010 | 01:55 PM
You don't. The housing is sealed. The only way to get the lens off is to place it in an oven and heat it up until the glue melts. Are you sure the inside is dirty and not the outside? You might need this instead:
http://www.autogeek.net/meguiars-pla...light-kit.html
or
http://www.amazon.com/Mothers-PowerB.../dp/B00341MIAW
Kirbyking12
04-29-2015 09:58 PM
W3MOT
02-08-2012 11:56 PM
crissy_s
07-10-2010 10:56 PM
artmathews
11-27-2009 08:44 AM
shiva
09-26-2004 04:30 AM
Quick Reply: headlights on 2004 sante fe gls
