How to check a fuel level sensor?
I am considering buying a 2007 Santa Fe limited (3.3L AWD) with 60500 miles on it. It shows a CEL and code P0464. The fuel gauge drifts from about a half a tank down to almost empty and back over a few minutes. Is there a relatively easy way to check the sensor with (for example) an ohmmeter? Is there anything else I should be aware of?
Thanks,
Terry
Thanks,
Terry
Thanks,
terry
Common problem, their are 2 fuel level senders, the one on the drivers side is on the fuel pump assy. and then the stand alone one is on the passenger side.
Both accessed from under the rear seat.
Sub-sender: 9 Ohms (Full) to 110 Ohms (Empty)
Main sender (fuel pump) 4 Ohms (Full) to 69.9 Ohms (Empty)
Enjoy!
Enjoy!
04prixgt04
07-10-2011 11:44 AM
