Hyundai Santa Fe Coolant Flush
Old 09-25-2011 | 04:16 PM
Mr. Pine's Avatar
Default Hyundai Santa Fe Coolant Flush
Hello all I'm new here and currently trying to perform a coolant flush on 2.7L 2003 Hyundai Santa Fe. I am trying to find a suitable place to drain the coolant. I was looking at two methods, drain through the valve or use the Peak coolant flush kit and force the old coolant out through a radiator cap with a water hose? Anythoughts? Thanks.
Old 09-25-2011 | 10:08 PM
ken99's Avatar
If you drain through the valve, you can capture most if not all of the coolant and dispose of it properly. I think flushing the coolant out through the radiator neck is illegal in all states since there is no easy way to collect or capture the coolant.
Old 09-26-2011 | 08:50 AM
Mr. Pine's Avatar
Yes I want to avoid doing the latter but the drainage valve is covered by the radiator support frame and is only accessible through the holes in the frame with a screw driver. I cannot see what it is I need to unscrew in order to drain properly. I wish I had a picture.
Old 10-05-2011 | 04:40 PM
Paul79UF's Avatar
The last few cars I've done, I just dropped the lower radiator hose into a large bucket and then refilled with a 50/50 mixture of coolant and distilled water.
If you do a drain and refill every 1-2 years, you don't really have to perform a flush.
Then again, if the coolant system has been ignored for 3-5 years, a flush is best.
Let us know how it goes.
Charles Robert Reed Jr.
08-03-2014 06:13 PM
cflsantafe08
02-27-2011 07:25 PM
zachunderwood
12-18-2010 09:17 PM
BottlefedLX
12-14-2009 09:39 PM
ken2400
11-11-2008 08:17 PM
