Key won't turn
Old 05-16-2007 | 08:55 AM
dgs615's Avatar
Default Key won't turn
My 05 Santa Fe's switch has been locking up with me, at certain time neither keys will turn in the ignition. doesn't matter if your on level or sloped surface. We have to keep fiddling with it, mashing the brakes, moving the steering wheel, the gear shift etc. and finally it will turn, Of course it doesnt do this for the Tech! and says unless he can duplicate it that the only way he can replace it is to charge us.
Is there anyone else having this problem?
Old 05-16-2007 | 12:25 PM
Doohickie's Avatar
Default RE: Key won't turn
Your tech is not competent. He should be able to examine the system and figure out what's wrong and replace it under warranty. If there is another dealer you can go to, I would try them.
I'm not familiar with the Santa Fe in this regard, but most cars have interlock cables that prevent you from starting the car unless it is in Park. I suspect a sticky interlock cable. If it only happens when the car is cold, let them keep the car overnight and they should be able to duplicate it.
HermanPWillis
03-22-2018 08:33 AM
Moesha
05-09-2017 06:20 AM
Tweedy-07
09-28-2013 07:53 AM
gvsuman
08-22-2007 08:25 AM
ttewejnodnarb
08-28-2006 12:36 PM
