Need a new rear tail light 07'
Old 01-25-2011 | 02:52 AM
ryan1428's Avatar
Default Need a new rear tail light 07'
Need a new pass side tail light bulb. I pulled off the panel. I see a wire and three screws. Is this all I need to take off the get the tail light out? And I think the bulb is the 1157. Please correct me if I'm wrong.
Old 01-25-2011 | 09:14 AM
SANTAFE(CM) >2007 > G 3.3 DOHC > Body Electrical System > Lighting System > Turn Signal Lamp > Repair procedures
REPLACEMENT
1.Disconnect the negative (-) battery terminal.
2.Loose the screws (3EA) holding the rear combination lamp then disconnect the 4P connector then remove the outside rear combination lamp.
3.Replace the bulbs (3EA) after disconnecting the rear combination lamp assembly.
4.Disconnect the lamp cover on tailgate. Remove the lamp assembly after loosening the connector (4pin), Cap nuts (2EA) and nuts (2EA).
5.Remove the tailgate combination lamp assembly and the replace the bulbs.
6.Installation is the reverse of removal.
Old 01-25-2011 | 03:34 PM
ryan1428's Avatar
Thanks. The pics are great. Did you find these online?
Old 01-25-2011 | 04:14 PM
http://www.hmaservice.com
Sign up for free.
Old 01-27-2011 | 02:38 PM
ryan1428's Avatar
I pulled the tail light. I got some good advice from another site. Put a rag below the 10mm nuts/screws so you don't drop them in to the bottomless pit. I bought some 1157 bulbs...when I pulled the burnt bulb it was an 1156. The tail light uses 3 different types of bulbs. One is a 1157, 1156 and what looks like a 168. Strange. Oh well....back to the parts store.
bogey883
01-16-2011 01:56 AM
f6typhoon
08-18-2010 04:39 PM
hicksville
04-09-2009 12:07 PM
MonoVersesStereo
12-09-2005 11:36 AM
accentgsi02
11-29-2005 09:57 PM
Quick Reply: Need a new rear tail light 07'
