New SFS, some questions
They work fine but you have to be careful of where the drain plug is located on the oil pan. If it's on the side you should be fine but if the drain plug is on the bottom, the valve might hang too low and risk being hit by something when driving.
Personally, unless you do a lot of driving to where you have to change the oil frequently, it's a waste of money.
As for "top tier" gas, don't waste your time. It's only marginally better and really only makes a difference on high-end cars. As long as you buy gas from a major brand, you'll be fine.
