Replace power liftgate 2019 Santa Fe XL
Old 08-25-2022 | 07:05 PM
Mdmacd1's Avatar
Default Replace power liftgate 2019 Santa Fe XL
I recently had one of the power struts on my 2019 Santa Fe XL break.
I purchased a new one and installed it but I feel like I missed a step. When I try to open it, it opens half way, beeps and then stops. Pushing the open button again just beeps with no movement.
I also tried disconnecting the battery for a minute and following the reset procedure in the manual (open gate, hold the Two buttons on the read gate until it beeps and closing it manually
Old 08-26-2022 | 06:15 PM
Can we ask where you purchased the replacement ? It is not unusual for certain parts to be defective right out of the box. I'm talking about parts from you know where.
We try to be discrete , but this is an on going quality control over profit problem.
Folks need to be aware of country of origin . The parts maybe cheaper but you have to buy them twice to maybe get a good one.
Old 08-26-2022 | 06:27 PM
Mdmacd1's Avatar
I got it from an Amazon reseller.
https://www.sellerratings.com/amazon...umpartswhosale
They seem to review well and it shipped from the US.thet was conciderably cheaper than buying from Hyundai.
Old 08-27-2022 | 06:29 AM
Amazon sells parts from all over. You need to ask where made.
Old 08-27-2022 | 06:42 PM
Mdmacd1's Avatar
Thanks. I contacted the vendor and based on the reply, I'm going to assume that they are out of China. I was just wondering if there is something that I missed before I work on a refund
Old 09-08-2023 | 06:49 AM
notsuitable's Avatar
Default Accèss to plug
When changing any tips on how to get to where the powered strut plugs in? Garage did the left 2 weeks ago and now the right has failed. Going to try and fix myself this time.
Old 09-08-2023 | 08:00 AM
Mdmacd1's Avatar
If I recall correctly, it wasn't that difficult. There is a panel just inside the door at the level of the plug. A small cover needs to be removed and a philips screw removed. Then the panel can be removed to access the plug.
I can see if I can get pictures later today.
Old 09-08-2023 | 09:57 AM
Thank you
Old 09-12-2023 | 04:21 PM
GENISIS's Avatar
If your under 60,000 miles this should have been a warranty item at no charge from Hyundai
amiller31
11-07-2022 05:59 PM
mohamed_salah
07-15-2021 07:57 AM
Bob Mathiebe
09-15-2020 07:26 PM
suvlover
04-30-2019 10:46 PM
CharlieMin
02-08-2019 07:34 AM
Quick Reply: Replace power liftgate 2019 Santa Fe XL
