Santa Fe 2012 Passenger window will not go up.
Old 09-11-2015 | 01:08 AM
dschrieber's Avatar
Smile Santa Fe 2012 Passenger window will not go up.
The window will not go up Do you have a Repair or service manual for that vehicle. Need some assistance. I started to take out the window motor on the front passenger door but I noticed the window regulator starting to move. I don't know the proper procedure to remove the motor.I need some help. I tried both switches drivers and passengers door. I also noticed when putting the switch in the down position you here a sound from the motor but when you place either switch in the up position I hear nothing. So my guess is its the wiring or the motor any help would be appreciated.
Old 10-01-2015 | 08:00 AM
quirkytones's Avatar
The issue maybe caused by a window motor failure. Try removing the door panel off and check for power at the motor connector when the switch button is pressed.
cefiro
02-22-2012 08:39 AM
Dpbuch
03-17-2011 04:45 PM
01tiburon
01-04-2008 09:08 AM
live2dream
01-16-2007 01:50 AM
