santa fe problems
santa fe problems
about a month ago i had to replace the timing belt and crank sensor , all went ok for a week and then the check engine light came on although the vehicle seemed to be running ok , now it has started to shut down while driving to 1000rpm it sometimes clears and carries on or if it does'nt clear switching off and restarting clears the problem for a while, i took it to have the lamp cleared and it has been putting up fault code po113,po102,po350 and po300 can anyone help. ( it is santa fe 02 4cyl petrol. )
