Santa fe won't start?!
Old 07-20-2008 | 07:59 PM
victordamasceno's Avatar
Default Santa fe won't start?!
I have a 2001 Santa fe GLS with ~82000 miles on it, and after not being used for about 1 week, fails to start. I don't think it's the battery because all electronics are working. It's weird because the key will turn but the ignition won't even click. I did notice that the (-) pole on the battery had a bit of build up on it and I cleaned it but still no go. Any suggestions?
Old 07-20-2008 | 09:10 PM
Default RE: Santa fe won't start?!
It's probably the battery. The "electronics" don't take much power to operare but the starter does. The battery probably has enough power to run the "electronics" but not enough to turn the engine over. This is very common. Make sure the battery cables are clean and tight then jumpstart the car.
Old 07-21-2008 | 07:46 AM
Ok, that makes sense. Then I have another question, what could have caused the battery to drain? Would that happen just because I didn't drive it for 1 week (you mention that this is very common) or has the battery just gone bad and I should replace it?
Old 07-21-2008 | 08:06 AM
How old is the battery? If it's very old, it just my not be able to retain a charge for a long period of time.
Also, there is a TSB about some Hyundai draining the battery when stored. I'll see if I can dig it up and post it.
Hibida
03-10-2011 01:44 PM
sipos
02-01-2011 08:45 AM
Hatdrawn
04-27-2010 09:49 PM
inspi
02-23-2009 02:39 PM
vincewturner
12-07-2006 02:44 PM
