Squealing belt, 02 2.7
Old 11-30-2011 | 06:35 PM
seanathin48's Avatar
Default Squealing belt, 02 2.7
Already put on a new belt and one new idler wheel, the other seemed fine. The belt will wonder and rub on the auto tensioner or will rub right on the engine, it rubbed through the plastic already, all the pullies turn ok, dont see or hear a wobble. The new belt was just a tad longer than the old one, maybe I need a belt just a tad shorter than the old one. The tensioner seems to be ok.
Old 11-30-2011 | 07:49 PM
ponderingjunkman's Avatar
Lightbulb
On my now deceased '03, the crank pulley went bad. The pulley is the outer part of the harmonic dampener. The pulley came unbonded from the rubber dampening medium, and would chirp and squeak. It did this for quite a while- several thousand miles- before it got too annoying and I figured out what it was. I'm really amazed it didn't come off! The LFD (local friendly dealer) had it in stock- something like 128 bucks comes to mind. Was easy to change thru the wheel well. Hope this helps...
Old 11-30-2011 | 08:11 PM
didnt think to check that, I did have 2 terrible strut mounts, terrible design, put it up on the lift and wam the struts fell right out, just held in by bonded rubber
Old 11-30-2011 | 09:23 PM
Front or rear? Went 216k with no trouble before the fatal accident...
petsnpotions
10-20-2010 09:16 AM
TOWNWRENCH
05-31-2009 08:37 AM
mu0ljk
01-24-2009 01:48 PM
pbf3267
10-31-2007 02:27 PM
jthomas
09-11-2007 11:12 AM
