Tools for 07' Santa Fe rear brakes?
Going to replace my sis in laws rear pads.
Questions:
Any specialty tools required?
Size of C-Clamp needed for caliper squeeze?
12 pt or 6 pt socket size for caliper removal?
I dont have my old $50k tool box any more so if I have to get anything I need to know in advance.
Thanks tons for your help.
Questions:
My questions to you:
- FWD or AWD?
- Are you replacing the rotors or just the pads?
- Are you also replacing the shoes for the drum parking brake in the rotor hat?
Answers to your questions:
1. No
2. Screw C-clamps, use this instead:
3. 6-point
PROCEDURE TO REPLACE REAR BRAKE PADS
1. Loosen the guide rod bolt (A) and pivot the caliper up out of the way.
2. Replace shims (A), pad retainers (B), and brake pads (C).
3. Push the piston in the cylinder using a SST (09581-11000) (or the tool I listed above)
4. Pivot the caliper down and tighten the guide rod bolt.
Tightening torque (lb-ft): 15.9 ~ 23.1
5. Installation is the reverse of removal.
- FWD or AWD?
1. No
3. 6-point
Thanks for the response.
FWD
Just pads
no on parking brk
Nice little tool. Not sure where to get it, probably more expensive that a simple C-Clamp. But sure, easy nifty tool.
6 point socket, any idea of size? Presume metric? Being an old dog that only bought american and used sae I'll have to buy the socket, trying to have everything ready & not turn it into an all day affair having to go buy tools after the job is started.
FWD
Just pads
no on parking brk
Amazon.com: Advanced Tool Design Model ATD-5050 Disc Brake Pad Spreader: Home Improvement
Amazon.com: Car / Truck Disc Brake Pad Spreader Puller: Home Improvement
Yes, metric. I want to say 12mm but I don't know that for sure. But that's usually the most common size.
the5threvolution
12-02-2010 11:14 PM
