Torque
RE: Torque
Anyone have a handy link for this?
Information is free, but you have to register and log onto the site. The info you are looking for is under the "shop" tab. You need to provide year, model and engine.
RE: Torque
FYI, torque specifications are sometimes listed in tabular form under "specifications", but most often they are listed in parentheses with a part designation in a system schematic under "repair procedure". Two or three numbers are usually listed. A key in the corner of the schematic will indicate which of the numbers is in english units (lb feet or lb inches). The actually verbiage of the menus varies somewhat, but once you pick up on this format, it's easy to figure out what you are looking for.
Good luck.
Good luck.
