Tranny is stuck
Old 08-11-2008 | 11:37 AM
simonlimon's Avatar
Default Tranny is stuck
Hi there, new to the site,
I have a 2001 santa fe(2.4 manual)is there a certain way to take the transmission off, iwas trying tochange theclutchbut the tranny wont come of the block, erery bolt was removed and there is nohing in the trannys way.
Old 08-11-2008 | 01:48 PM
Default RE: tranny is stuck
Sounds simple but did you remove the half-shafts?
Old 08-11-2008 | 02:10 PM
simonlimon's Avatar
ORIGINAL: NovaResource
yea i removed them
Old 08-11-2008 | 02:37 PM
REMOVAL
1. Remove the battery terminal.
2. Remove the battery tray.
3. Remove the air cleaner.
(1) Upper
(2) Lower
4. Remove the back-up lamp switch.
5. After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.
6. Remove the speedometer driven gear connector.
7. Remove the clutch release cylinder mounting bolt.
8. Remove the cotter pin of the shift cable (transaxle side).
9. Remove the cotter pin of the select cable (transaxle side).
10. Remove the clip of the shift cable (transaxle side).
11. Remove the clip of the select cable (transaxle side).
12. Separate the steering column shaft joint.
13. Separate the power steering oil pump hose.
NOTE:
Be careful not to leak after separating.
14. Separate the hose after removing the clip of the power steering return hose.
15. Remove the upper connecting transaxle bolt.
16. Separate the start motor.
17. Install the engine support fixture.
18. After removing the tire, remove the caliper.
19. Separate the tie rod end.
20. Remove the wheel speed sensor and the knuckle mounting bolt.
21. Drain the oil.
22. Remove the transaxle mounting bracket.
(1) Insulator bolt
(2) Body side mounting bolt (Upper)
(3) Body side mounting bolt (Side)
(4) Transaxle side mounting bolt.
23. Remove the front roll stopper.
(1) Insulator bolt
(2) Stopper bolt (Upper)
(3) Stopper bolt (Lower)
24. Remove the rear roll stopper.
(1) Insulator bolt
(2) Stopper bolt
25. Remove the drive shaft.
26. Remove the muffler.
27. Remove the sub frame mounting bolt.
28. Install the transaxle jack.
29. Remove the transaxle lower mounting bolt to the engine.
30. Remove the transaxle assembly.
INSTALLATION
Installation is the reverse of removal.
Old 08-04-2009 | 08:30 AM
mgcmn's Avatar
Default Tranny stuck
I don't have the answer yet. However I know that the throwout bearing snaps onto the pressure plate once reassembled and the clutch is depressed for the first time. I will update you as soon as I know. My tranny is hanging as well.
Mgcmn
Old 08-04-2009 | 06:38 PM
mgcmn's Avatar
Ok, I have the answer to the problem. You have to remove the nut holding the clutch release lever on. This should allow the shaft to turn enough to release from the pressure plate. Also says that you will have to lower sub frame. I will try without doing this first. Good Luck hope this helps.
Old 08-05-2009 | 07:38 AM
jsinton's Avatar
Banned
Yes, indeed. Had I seen this earlier, I would have told you that. You have to remove that clutch release arm, or it's almost impossible to separate. I've read stories about guys destroying the old clutch trying to pry it loose with crow bars.
Old 07-05-2011 | 07:45 PM
xEliteDreameRx's Avatar
Default help
so how would you remove the lever on 2006 tiburon
sweettrik79
02-09-2009 09:13 PM
southgatib24
01-27-2009 10:44 PM
ron412
03-18-2008 11:09 PM
first choice
06-06-2006 11:18 PM
olboggy
02-13-2006 06:49 PM
