01 sonata power steering line
Pressure line leaves the power steering pump and heads to the spool valve on the rack.
Return line runs from spool valve across top of rack, then along right frame rail to bottom corner of radiator, continues into rubber to the cooler tube in front of radiator, and returns to P/S fluid bottle.
Return line likes to trap road water/debris in the rubbe tube they put over the steel line along the frame, rots out and squirts P/S oil oil all over the place.
Pressure lines start to get wet look, and the joint at the mounting clamp at right side of rack gets all wet.... flash light and eyes will guide you.
