02 Sonata Squealer
RE: 02 Sonata Squealer
I would check the Waterpump ASAP. I had the same problem with my 02 Sonata. The squealing would happen when I started the vehicle and would fade away after about 3-5 minutes originally. Then it became a consistent thing. BTW, if the tech recommends to replace your timing belt while they're in there doing the work anyway, DO IT!!! I didn't (couldn't afford the $450 bill) and the timing belt went at 80k miles. It's now back in the shop with either a cracked block, blown head gasket or something like that. I'm not sure yet, the tech hasn't finished diagnosing the problem. Anywho...he said that the oil was fine (it should've been. I put 4 qts in it over a 1 1/2 wk time period) but the coolant looked like chocolate milk. Now I'm looking at what he estimated about another $1500 repair bill on top of the $1800 I put into it from the belt going on it. And to top it off...none of it is covered on ANY warranty because I didn't change the belt when the tech recommended it.[:@]
