2001 Sonata - Input/output Speed Sensors , Diy ?, Should I do it, or pay them too ?
Old 05-28-2008 | 01:16 AM
omnipotent goku's Avatar
Default 2001 Sonata - Input/output Speed Sensors , Diy ?, Should I do it, or pay them too ?
I have a 2001 sonata with a list of various problems. Among them is the "limp" mode where my transmission
- My timing and serpentine belt need to be changed. (overdue)
- "limp" mode where my transmission gets stuck in 3rd gear
- Throwing the following codes.
P0715 (no input speed sensor signal - open/short)
P0720 (no output speed sensor signal - open/short)
I took this info to my dealer, to get a quote on parts and labor. Overall to replace the timing and serpentine belts, input and output sensor, would be $792 .
The timing and serpentine I will have them do, but I question the input and output sensor as I have seen them in pictures on top of the transmission. My understanding is that they are supposed to relatively accessible from under the airbox.
So my question: Should I just order the Input output sensors and do that myself? Is that portion easy enough to do ?
Any input would be greatly appreciated.
Old 05-28-2008 | 09:23 AM
Default RE: 2001 Sonata - Input/output Speed Sensors , Diy ?, Should I do it, or pay them too ?
I am thinking that I am going to attempt some junk yard triage in the next few days. I am also in need of a new window motor as one of my windows is stuck down. Have you or anyone ever attempted to replace those sensors ? Thats my biggest concern currently.
Old 06-03-2008 | 06:10 AM
major15001100's Avatar
hi omnipotent gokuthis job on your sonata is very easy, the battery will need to be removed so the airbox can be taken out, (small 10mm bolt between the fuse box and the airbox) once this is out one sensor will be sitting just under the selector cable (2 12mm bolts to remove) and the other sensor will be sitting further back, but is easy to get to even without taking the airbox off. hope this helps
Old 06-03-2008 | 10:23 AM
ken99's Avatar
Isn't there a small pigtail that runs between the two sensors that sometimes shorts out? Maybe that's just a problem on the Accent.
ejc2180
04-23-2021 02:55 PM
todd2001accent
03-13-2012 02:45 AM
DCCD
02-17-2011 09:01 AM
GOODWAY
01-21-2009 09:30 AM
BTLew81
03-03-2007 12:54 AM
