2001 sonata multiple engine misfire
Old 08-25-2009 | 06:36 PM
jim tjernlund's Avatar
Default 2001 sonata multiple engine misfire
having problem with multiple engine misfire,very bad when engine is cold,once it warms up it runs fine, any ideas?
Old 08-25-2009 | 10:01 PM
jsinton's Avatar
Banned
Could be all kinds of things. Did you do a code scan? Is there a check engine light?
Old 08-26-2009 | 04:43 AM
Default Reply
Was checked with a basic OBD scanner and pulled a 300 code which is multiple engine misfire. I'm thinking it must be a sensor or some computer related problem...any idea's?
Old 08-26-2009 | 08:37 AM
jsinton's Avatar
Banned
Could be a lot of things. I'd start by changing the plugs and wires.
From odb-codes.com:
A code P0300 may mean that one or more of the following has happened:
* Faulty spark plugs
or wires
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector(s)
* Burned exhaust valve
* Faulty catalytic converter(s)
* Stuck/blocked EGR valve / passages
* Faulty camshaft position sensor
* Defective computer
inyourface1650
08-23-2011 01:06 AM
finsfan
06-12-2007 06:16 PM
JLF
05-13-2007 07:06 PM
rollerdawg
08-09-2006 08:32 PM
