2001 W/ high idle
Old 04-04-2009 | 09:40 AM
fuelman's Avatar
Question 2001 W/ high idle
Hello all,
The Sonata idles at 1800rpm in park/neutral. The idle doesn't change from cold start to full operating temp. When in gear the idle is pulled down to 900rpm and when the A/C compressor cycles the rpm will increase about 50rpm, so I think the idle control servo is working but I'm not sure. There is NO check engine light. The engine occasionally runs rough and lacks power. I removed and inspected the intake hose looking for leaks and found none.
I need your help!
Thanks
Old 04-05-2009 | 08:55 AM
jsinton's Avatar
Banned
It's probably the ICS valve if there's no intake leaks. You can test it by removing the thing and plugging up the holes. Did you do a code scan anyway? Don't drive like that too much, as it will burn up your transmission.
Old 04-05-2009 | 07:56 PM
fuelman's Avatar
Yes, tested for codes and found none. Today I drove it a little then parked for awhile, when I re-started it idled at 800RPM but as I drove it home the idle returned to 1800RPM.
I guess if I remove the IACS and plug the hole it would narrow it down a little, Throttle Position Sensor, IACS, or something else telling the IACS to open the throttle.
Old 04-05-2009 | 08:46 PM
jsinton's Avatar
Banned
It won't idle high unless it gets air. It's either getting air from the IAC or an intake leak.
Eagle29
04-17-2019 11:09 AM
D&L
02-04-2009 12:20 AM
ChrisV
01-29-2009 03:08 PM
tacman
01-15-2009 01:26 PM
tony b
01-18-2007 03:40 PM
