2003 Sonata won't start
Old 07-05-2009 | 01:22 PM
mlcoats's Avatar
Unhappy 2003 Sonata won't start
Remote would not open doors even though light on remote came on. Opened door with key. Alarm went off but sounded weak. Found out headlights had been left on. Car would not start. Tried to reset alarm by putting key in ignition and turning to on position for 30 seconds. No luck. Checked all fuses and fusible link on battery. All good. Removed battery and had tested. Battery was at 29%. Replaced battery. Now have clicking noise at starter and behind fuse box under dash. Still won't start. Also power windows won't operate. Everything else works; lights, turn signals, brake lights, door locks, etc. What else can I check to get it started? Thanks in advance. Mike.
Old 07-05-2009 | 02:24 PM
jsinton's Avatar
Banned
You replaced the battery, but how do you know the new battery is good? Did they check it before installing it?
Old 07-06-2009 | 10:51 AM
mlcoats's Avatar
Yes, even tried to jump start.
Thanks,
Old 07-06-2009 | 11:10 AM
jsinton's Avatar
Banned
Sounds like you have more problems than just a weak battery. You need someone on site to do more troubleshooting, as it's impossible to make educated guesses on some forum on the internet.
Old 07-06-2009 | 01:14 PM
mlcoats's Avatar
Thanks for your reply. Nothing is simple anymore. I'll probably wind up having it towed in.
sipos
02-01-2011 08:45 AM
Hatdrawn
04-27-2010 09:49 PM
jareddbh
08-29-2009 01:47 PM
faint06
06-12-2009 08:39 AM
caper
12-07-2006 03:00 PM
