2004 sonata defogger
Has anyone replaced rear window defogger relay, 2004 Sonata?? I know where relay is, but can"t remove it. Power window and door lock relays are on same fuse block in passenger compartment.Accessing any one is all the same.
Thanks for help yenoocpb
Can hear relay operate.When it does it should supply power to ;rear window, also supply power to another fuse that lights indicator on switch, no power to that fuse or rear window, no indicator light on switch. There is not much room to access relay and can't get a good grip.The defogger relay is located on same fuse block as power window relay and door lock relays. If you have changed or removed any of these, method would be helpful.They are located in passenger compartment behind driver side crash panel.
thanks yenoocpb
thanks yenoocpb
glassfern53
09-05-2015 03:47 PM
Andy123
02-02-2015 02:37 AM
