2008 Sonata Horn Switch Replacement?
Hello all,
I'm looking for some guidance on replacing the horn switch in my 2008 sonata.
The relay is fine, if I jump the relay In the fuse box, the horn sounds, and lastly the horn sounds when hitting the panic button on the alarm.
I feel pretty confident that the clock spring is fine, as my cruise control and other steering wheel buttons function without an issue.
If anyone is able to provide any guidance as to where the horn switch is located as well as a valid replacement part, it would be greatly appreciated. Having this information before I disassemble the steering wheel should hopefully make things go much faster!
Thanks in advance!
-Nick
Thanks in advance!
-Nick
I have not taken the steering wheel of a Hyundai but of a Ford product. I encourage you to go into it. Most likely the horn switch is accessible once the airbag has been removed. That's taking off the battery negative and 2 screws on the backside of the steering wheel.
Look for a video that relates to replacing the clock spring on any Hyundai/Kia.
