2010 sonata wiring guide
Old 09-25-2010 | 09:52 AM
dylan4566's Avatar
Default 2010 sonata wiring guide
does this exist? im not happy with the factory stereo, and wanted to replace it with anoter double din radio. problem is that i cant seem to find one online, and crutchfield states that they dont have specific installation instructions for a 2010. any help would be appreciated
Old 09-25-2010 | 12:59 PM
Sign up for FREE account at www.hmaservice.com , and look at site requirements and them.
From the select ETM, select vehicle by model, year, engine from drop down boxes, and run.
Old 09-26-2010 | 12:55 PM
ken99's Avatar
The information provided by Sbr711 will get you to the wiring schmatics, but will not explain how to remove the radio. Here are those instructions.
SONATA(NF) >2010 > G 2.4 DOHC > Body Electrical System > Audio > Audio Unit > Repair procedures
Replacement
1.Disconnect the negative (-) battery terminal.
2.Remove the console under cover (B).
3.Remove the side garnish(A). (Refer to the Body group - crash pad)
4.Remove the center garnish(A).
5.Remove the crash pad center facia panel(A).
6.Remove the clock connector(A) and heater control unit connector(B).
7.Remove the mounting screws then remove the audio unit (A).
8.Remove the the audio unit connectors and cables(A).
9.Installation is the reverse of removal.
Old 11-04-2010 | 11:41 PM
dallows's Avatar
Where did you get those instructions? Thanks.
Old 11-05-2010 | 08:28 PM
ken99's Avatar
From the hmaservice.com site.
cyclopsnine
10-18-2010 12:28 PM
flibottf
01-06-2009 10:28 PM
scopitone
12-03-2008 06:26 PM
JimMayor007
07-03-2007 06:38 PM
eck5150
04-26-2006 02:50 AM
Quick Reply: 2010 sonata wiring guide
