2011 hyundai sonata - Left (driver's side) Headlamp Assembly Replacement
I removed the two top bolts easy... but that third bolt is killing me, I have no ideal what ratchet drive size & depth to use. The third bolt is beneath the headlamp assembly, it looks like I might have to remove the battery for space to work,- (I have very large hands) but I want to avoid moving the battery.
Removal
1. Disconnect the negative (-) battery terminal.
2. Remove the front bumper.
3. Loosening the head lamp mounting bolts (3EA) and disconnect the head lamp connector. Then, remove the head lamp assembly (A).
- Take care not to scratch the head lamp lens or fender.
Take care that holding clip (A) is not to be damaged.
